ORB initialization timed out (IDEAS NX 10)
all was working fine, but, system administrator remove my machine from a domain and put it on a workgroup and change the machine name in windows properties.
now, i´m having this error when i try to import or export an IGES file.
the error message is:
"Open I-DEAS initialization failed because ORB initialization timed out. The mos likely reason for this is that one of the Orbix services is not responding. It is recommended that you terminate I-DEAS immediately and check whether the Orbix services are working.
Clik Ok to terminate I-DEAS"
then, i have 2 options. OK or CANCEL. if i click OK, it close IDEAS, and if i click CANCEL, it closes the "warning window" and returns to I-DEAS.
what can i do to resolve this problem whithout reinstalling I-DEAS system again?
i´m runing it on a WXP SP2 and my user is de machine administrator.
thanks
thanks
RE: ORB initialization timed out (IDEAS NX 10)
i´ve discovered that the problem was generated by the changing of machine name.
how can i change this setting and keep IGES working fine?
thanks
you´re right, the problem is the machine-name in the scripts in %ideas%\Iona\OrbixE2A\etc\bin .
You´ll have to remove and reinstall the orbix-services.
simba69
i will try this next time :)
[]'s
