Lifeform Energy Fields
As an antenna engineer I am aware that current flow stimulates EM fields around conductive structures. These fields can affect the surrounding atmosphere, charging cerain particals. MRI scanners work based on the bodies response to induced fields, but it should also be possible to map the inherent fields of a lifeform induced by its nervous system. I have yet to see any studies in this area.
Please indicate whether you know of any such studies even in embryonic or conceptual stages. Also indicate if you have an interest in such a study and whether you would care to participate in one of our own devising.
Best Regards
RE: Lifeform Energy Fields
i believe this is known as kirliean photography. (not sure on the spelling). in its simplest form it consists of an object (leaf / hand / person) being charged up vs a metal plate with a photographic film on it. the photo paper then records a series of blobs around the human body. lots of strange things gop on - good mood, bright blobs, bad mood (ill) small blobs. im sure there will be websites on this
Medicine has been researching that for years and they use it now for prototype prosthetics(sp?).  Recently a monkey with some implants was able to move a computer's cursor by thinking about it.  Try looking under bionics or neural implants.
