Working Depth and Whole Depth of Metric Helical Gears
What is the rule of thumb for the root diameter for metric helical gears? Isn't it (#teeth-2)*module for spur gears?
Working Depth and Whole Depth of Metric Helical GearsWorking Depth and Whole Depth of Metric Helical Gears(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Working Depth and Whole Depth of Metric Helical Gears
Usually it is (#teeth-2.25)*module, what creates 0.125*module clearance between the meshing gears' root and tip.
I agree with your formula for root diameter, but assuming the usual 2*module working depth, you would get a tip to root clearance of 0.25* module, not 0.125*module.
Root RADIUS is half of that value, it means it is 1.125*m smaller than pitch radius. The meshing tooth' addendum = module, subtracting the addendum we'll get the clearance (0.125*m)
Of course, we are still talking about the standard ("N") teeth on both meshing gears; the pitch diameters (z*m) are tangent (they are operating diameters as well).
(the symbols in formulas above mean: z = # of teeth, m = module)
1.00 so .25 is the clearance. You do not
divide the 2.25 ratio by 2.
Philrock is correct about this.
There are also two ways of cutting helicals
in Europe so caution is needed.
If a rack cutter as Gearguru suggests is
used then the above applies.
If dedendum is 1.25*m (depends on the rack) then
root diameter = pitch diameter - 2.50*module.
In such case I agree that the clearance is 0.25*module.
But in my example above the root dia = pitch dia - 2.25*m,
I calculated with the rack with 1.125*m addendum. For my example the clearance is 0.125*m.
The original question was "What is the rule of thumb for the root diameter", I answered it and calculated the clearance using that answer.
You did not mention that in your case the root dia is pitch diameter - 2.50*module
Well I did read that too quickly.
Most module gearing was 1.166 times
the module until the last 8 years
where 1.25 times the module was adopted
for full depth gears. I have not seen
1.125 times the module on a rack so I
made the wrong assumption. Sorry!
