vibration analysis on semi-hermetic compressor
i'm working on a trane compressor m# CRHR600C-7RA0
s# J08031266AR which was installed about 6-months ago. it is making a unusual noise (sound like metal on metal) the compressor has a one-year warranty from the rebuild company. i want to try to get it replaced while it is still under warranty. my problem is that the compressor is still working properly. i fell like it is going to go out eventually. Has any one ever heard on getting a vibration analysis done on a semi-hermetic compressor. i fell that if i had a vibration report, i would have grounds to get the compressor replaced under warranty.
RE: vibration analysis on semi-hermetic compressor
This is a system problem, not a compressor problem. But it will destroy your compressor.
Find and fix the problem in the system.
Mark Hutton
