using the fit spline tool???
Do any of you guys use the Fit Spline command on a regualr basis? If so are you experianceing very slow performance when using it in SW05 vs SW04? For the most part I have been happy with the 05 relase (I know it contradicts some opinions) but this is bad. Some of the geometry that I had been using in 04 would take 20-30 seconds to compute a fit spline now it is taking 5 min using the EXACT same geometry. I hope that there is something I can do about this. Thanks... Im done ranting now.
Mike
Mike
RE: using the fit spline tool???
Have you read the Slow downs FAQ here yet?
I have not seen the Fit spline cause any slow downs. If you are seeing them then you need to take the time to figure out if something has changed on your box or if you need to do system maintainence on your Box. If you are working over a network, move the file locally and see if that helps.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
How many sketch elements are you converting to a spline? If you have a lot, this will draw on your resources substantially. If you have less than ten, I'm guessing you have a hardware deficiency somewhere like Scott suggested. Check it out and let us know what you find.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Mike
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Mike
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
