Dynamic v Couple Unbalance
If I know static imbalance in two different planes, I can calculate couple imbalance.  Dynamic imbalance is the "combination" of couple and static imbalance.  If I know static imbalance and couple imbalance, how do I calculate dynamic imbalance?
RE: Dynamic v Couple Unbalance
You speaking in terms of tires or wheels?  And why not just take the wheels/tires to a service center & see if they will check the balance for you using the appropriate equipment to reduce the possibility of error?
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
I'm speaking in terms of DC motor armatures.  I just figured if anyone would know about balancing rotating machines, it would be wheel and tire guys.
You also need to know the cross coupled imbalance before you can work out the true state of affairs.
That is, you need three pieces of information
- the change in response (in phase and magnitude) at measuring plane 1 to a trial mass on plane A  call it R1A
and
R2B
and
R2A or R1B, but preferably both
Cheers
Greg Locock
Do you need to resolve the "static" and "couple" already derived by some measuring method ( probably using Greg's method) into appropriate left and right plane corrections?
Add 'em up vectorically or graphically.
The couple is 2 equal and opposite imbalances separated by some distance.  Choose that distance as your distance between correction planes.
Then break the "static" unbalance into 2 equal pieces, and add one to each end.
