format
format
This might sound simple to some of you, but what is the difference between a fixed format file and a free format file? Can they be mixed together in projects? If a subroutine is written in one format can it then be re-written in the other without making changes?
John
John
RE: format
Now if you are speaking of the format of Fortran source files, as your last sentence suggests, you can have one file be in fixed format (statement numbers in columns 1-5, continuation character in column 6, statement body in columns 7-72), and another file be in free format (no column designations, lines to 132 characters, different designation of continuation lines), and compile each file separately, telling the compiler which form to expect for each. Your compiler may have a command line or default switch telling it which form is given, or it may take the form from the file extension; the Lahey LF95 compiler offers both ways. But you can't combine files so that one part of the file has a subroutine in fixed format and another has a subroutine in free format. Refer to your Fortran language manual for rules on the different forms.
RE: format
RE: format
