need difference equation and for loop help
I'm attempting to solve a difference equation
y(k+1) = -0.5*y(k) + x(k)
where y(0) = 0 and x(k) is in my case a unit step function ie = 1
well, i'm trying to solve this using a for loop, but am having some trouble. The code i've generated gets an error, "Index into matrix is negative or zero."
Any ideas?
My code is below.
k = 0 ; %counter variable
y = 0; %y(k)
x = 1; %x(k), unit step function
for k = 0 : 5
y(k+1) = -.5*y(k) + x;
y(k) = y(k+1)
end
RE: need difference equation and for loop help
Well, the error message seems pretty informative.
If k is zero and you call y(k) what else would you expect?
Cheers
Greg Locock
MATLAB matrix indices start at 1, not 0.
xnuke
"Do you think you used enough dynamite there, Butch?"
