Airbus A319/320 Help
I need help with an A319/320 Hydraulic Access Door: D5347501404600.
The bonded door has an internal coating for hydraulic protection. The Drawing PL shows "DAN95M Protective Foil" as the last coating.
This door has a molded plastic film, much thicker than Tedlar, that doesn't have the appearance of Foil. It is a Lime Green color and appears to have been bonded on at cure.
Does anyone know if this is in fact the DAN95M Protective Foil called out in the Drawing.
Rerig
Rerig
RE: Airbus A319/320 Help
