Wall stud deflection
Here in Florida our new code now contains language taken from the International code limiting stud deflections due to lateral (i.e. wind) loads . Distinction is made between brittle and flexible finishes. If I consider stucco to be a brittle finish I am hard pressed to get a 2x4 framed wall to work for even single story applications. For those of you in other parts of country with higher wind speeds, how are you handling the deflection criteria?
RE: Wall stud deflection
DaveAtkins
DaveAtkins
