Flange Literature
Flange Literature
Flange Literature
I was wondering if anyone had any suggestions for useful literature/text books for the design of flanges?  I work in the pressure vessel field (both ASME III/VIII) and am looking to obtain more useful information.  I already have Taylor Forge Bulletin 502 btw.
Thanks for any help any of you can give.
RE: Flange Literature
Reesh, did you get Bulletin 502 recently? If so can you provide a source, mine's about worn out.
Unfortunately no.  I got it a few years ago from a colleague who retired.  He had had it for years before that.  It's not in the best shape either.
Sorry.
SNTman, I have an electronic copy if you like.  Testdog2000@yahoo.com
Here's a few:
"A PVRC Monograph of the 1949 Classic" "Development of General Formulas for Bolted Flanges"  by Waters, Rossheim, Westrom & Williams.  It has the derivation of all those flange factors.
Taylor Forge Bulletin #45 "Design of Flanges for Full Face Gaskets."  Has the "Modified Rossheim Method" for full-face gaskets
A.E. Blach, "Bolted Flange Connections for Non-Circular Pressure Vessels" ASME PVP-158, 1989. pp. 97-104.
Cook & Guerreri, "Deflection in Gasketed Joints, Machine Design{I think}, March 14, 1968, pp.149-50.
R. Swick, "How much pressure will that Gasket Take?" Machine Design Nov. 24,1977
WRC #314 "Bolted Flange Connections with Full Face Gaskets," by Blach, Bazergui & Baldur, May 1986.
Also check out the Dutch Stoomwesen, BS5500, etc. flange analysis methods - a little bit different than ASME App. 2
Thanks for the input arto!
Much appreciated.
Reesh, that's how you get everything for this industry.
Me to Coworker: Where'd you get that?
Coworker: Well, I had it.
Me: Think I can get one?
Coworker: No.
All the good books are out of print.
TD2K, thanks, will take you up on that.
