Removal of rust contamination on SS
In the past we've used products such as Avesta's pickling paste on s.s. to clean up small isolated areas exhibiting oxidation. I have several plates ( 2205 ) which came in from our vendor with rusty scratches. Normally, I'd reject them and have them replaced, but, in this case due to delivery constraints, that isn't an option. Has anyone any other suggestions for cleaning these areas?
RE: Removal of rust contamination on SS
unclesyd, Can you provide a manufacturer or supplier for the H3PO4.
yates,
I'm not familiar with AMS QQ PP-35, any idea where I can find additional info?
thanks again,
Use all at 100% concentation.
Citra-surf will work, as will phosphoric, but why reinvent the wheel?
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
