Member Login
Are you a
Join Eng-Tips now!
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...What a great service! This is the best site I've ever seen!!! It totally restores my faith in humanity when people take time out to help other people..."
Geography
OilBoiler (Chemical)
30 Mar 05 13:47
Hey everyone!
I'm looking at a project for which the fuel gas to a heater may vary widely in BTU content, because of the PSA unit swings.  Do you know of control loops for this type of swings? Is it a control loop based on a BTU analyzer? A control valve for the fuel gas?
Thanks in advance,
jsummerfield (Electrical)
30 Mar 05 14:49
Furnace controls can be as simple or complex as you may desire.  Schemes exist that evaluate the heat content of the furnace feed, the heat content of the heater outlet, the energy content of the fuel, perhaps even the waste heat issues associated with the stack effluent.  Some of the complex schemes have been around for over 25-years.  Similar simplicity and complexity exists for the furnaces (FD, ID, waste-heat recovery, air-preheat, multiple burner, multiple fuel ...) and for the safety shutdown schemes.  I may look for web links later.
John
drewd01 (Electrical)
12 Apr 05 6:02
One way of inferring the calerific value/BTU of the fuel gas (at least to give your controls a 'heads up' that it is changing) is to measure the gas density, possibly via a coriolis measurement. This can then be used to modify the fuel flow controller.
12 Apr 05 11:28
In addition to BTU there are analyzers that measure the Wobbe Index.  The Wobbe Index as saved from one of the manufacturers is the ratio of the heat of combustion of a gas to its specific gravity. For light hydrocarbon gases the Wobbe index is almost a linear function of the gas' specific gravity.  The Wobbe Index is the number obtained by dividing the saturated heating value of the gas by the square root of its specific gravity.  Wobbe index is a measure of the amount of heat released by a gas burner of constant orifice.  It indicates the quality of the gas and is given by the expression Vp0.5 where: V = the gross calorific value in BTU per cubic foot at STP and p = specific gravity.
You can use Wobbe Index or BTU as a measurement instrument in a combustion control scheme.
John
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Control Systems engineering Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=830
DESCRIPTION: Control Systems engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
