looking for 25x47x14 wheel bearings?
I'm doing a fork conversion on a motorcycle and need an unusual wheel bearing size, 25x47x14.
Is there anyone who can help?
RE: looking for 25x47x14 wheel bearings?
6005 bearing is 25x47x12, use a spacer for width
Russell Giuliano
Unique Technologies Associates - Cobra Solid Lubricant
www.uniquetechnologies.com
You have not given up yet.
You can have it custom made
at one heck of a price.
If you cannot use one or
two spacers and use the
standard 25x47x12 bearing
you are going to spend a lot
of money.  I think there is
also a 20x47x14 available.
You can also get a 6204 bearing (47mm OD x 14mm width) with either 5/8" bore or a 3/4" bore. These are slightly special, but readily available
Part# 6204-2RS-12 for ¾"
      6204-2RS-10 for 5/8"
Russell Giuliano
Being a wheel bearing is this a tapered roller bearing?
