Portable Fire Extinguisher Requirement
We have a computer room which is protected by an FM-200 fire suppression system, EPO system and sprinklers. When this building was built in 1996/7 there were no fire extinguishers installed in this computer room.
I have looked though NFPA-1 (2003), OSHA 1910 and local codes but cannot find anything that specifically says a computer room is exempt from portable extinguishers simply because it has protection by a fire suppression system and/or sprinklers.
Does anyone know anything different? We haven't been cited for this by the local or State agencies nor has our insurance inspector said anything.
RE: Portable Fire Extinguisher Requirement
You could also check the NFPA 101 or NFPA 75 to see if it contains clues for your case.
