Low Temperatures and Structural Steel
I am trying to locate usable information regarding the correct steel to specify for a freezer building where temperatures can range from 36 degrees F to -40 degrees F. I have a client that encloses the steel structure inside the thermal envelope thus subjecting the steel to freezing temperatures. Their drawings use only simple connections and rod bracing. Any direction, guidance, or suggestions would be greatly appreciated!
RE: Low Temperatures and Structural Steel
