Rotate Drawing Using VBA
I am trying to determine if a drawing is longer Vertically than it is Horizontally. If it is I want to rotate the drawing by 90 degrees.
Does anyone have any idea how to check the max dimensions using VBA and then how to rotate the drawing?
I used to do this in Lisp using the following
(setq mx (getvar "extmax"))
(setq mn (getvar "extmin"))
(setq width (- (nth 0 mx) (nth 0 mn)))
(setq height (- (nth 1 mx) (nth 1 mn)))
(if (> height width)
(command "rotate" "all" "" "0,0" "90")
(command "Zoom" "E")
I would like to do the exact same thing. Barring that I would like to just run this chunk of LISP code from VBA if that is possible.
RE: Rotate Drawing Using VBA
Sub RotateTallDwg()
'RotateTallDwg:
Dim vMX As Variant
Dim vMN As Variant
Dim acSS As AcadSelectionSet
Dim acItem As AcadObject
Dim dPt(0 To 2) As Double
vMX = ThisDrawing.GetVariable("EXTMAX")
vMN = ThisDrawing.GetVariable("EXTMIN")
If (vMX(0) - vMN(0)) < (vMX(1) - vMN(1)) Then
Set acSS = ThisDrawing.SelectionSets.Add("DWG")
acSS.Select 1, vMN, vMX
dPt(0) = 0: dPt(1) = 0: dPt(2) = 0
For Each acItem In acSS
acItem.Rotate dPt, ((Atn(1) * 4) / 2)
Next acItem
End If
End Sub
"Everybody is ignorant, only on different subjects." — Will Rogers
