PDMWorks API
PDMWorks API
Ok, so I don't know if I'm completely missing the boat here, but...I'm trying to write a VB program to change the descriptions of a few hundred parts in my PDM system. I can log into the vault, take ownership of a document, and access the description of the part, but I can't change the value of the description. In addition, I also have several other custom parameters that I want to change, but have been unsuccessful in doing so. I've tried using the syntax described in the API help, but it just doesn't seem to work: PDMWProperty.Value = pVal
So, if anyone could post a line of code that will simply change the description of a part (in the vault) to the string "NEW DESCRIPTION", I'd be very grateful (this could all be related to the fact that I'm very new to VB). Thanks
RE: PDMWorks API
Do you have PDM Advanced Server?
Bradley
RE: PDMWorks API
RE: PDMWorks API
I am not running Advanced Server either. To my understanding you cannot change anything inside the vault through standard API. If you figure this one out let us know. I am sure I could find some use for a tool that would change things inside the vault.
Bradley
RE: PDMWorks API
[get and set the document you want]
PDMWDocument.Properties("Description") = "New Description"
RE: PDMWorks API
How does one link up to the PDM vault to change a property without running Advanced Server?
I looked at the SolidWorks Task Scheduler and I do not see anyway there of updating properties within the vault.
Bradley
RE: PDMWorks API
http
RE: PDMWorks API
It may say that on the website, but API is now included with PDMWorks 2005. I'm running it right now, and I don't have a license for advanced server.
RE: PDMWorks API
Sounds like to me that flatwire would have to check-out the drawings and part models and change the properties using VB then check them back-in. He could have an admin do a bulk check-in.
Bradley
RE: PDMWorks API
Dim part As PDMWDocument
Dim propertiestlist As PDMWProperties
Dim errorcode As Long
Set part = conn.GetSpecificDocument("test.SLDPRT")
part.ChangeOwner ("pdmwadmin")
Set propertieslist = part.Properties
part.Propertiest("Description") = "SAMPLE DESCRIPTION"
errorcode = propertieslist.Update()
part.ReleaseOwnership
So basically, I took ownership of the part, put all of the properties into a variable, changed the description, and then updated the vault to reflect changes I made. The key was updating the propertieslist variable. If you've got any questions, let me know.
RE: PDMWorks API
Evan T. Basalik, MCSD
It's all about prioritization...
RE: PDMWorks API
RE: PDMWorks API
