Valeo HDFS hydraulic motor
Can someone tell me what's inside this motor? It's a hydraulic engine cooling fan motor used on newer Chrysler products. I see some images online where the external motor casting shape looks a bit odd to me. I would like to know what type of motor is inside.
http://d esignserve r.rit.edu/ Archives/P 04016/0401 6VALEO.pdf
Thanks.
http://d
Thanks.
RE: Valeo HDFS hydraulic motor
The Valeo motor appears to have three ports and they are not opposite across the shaft center, they are approximately 90 degrees apart. Hence my question.
