EDrawings to Solidworks file?
RE: EDrawings to Solidworks file?
You can not create a part from the eDrawing. You can measure it, then create new from the dims.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
If they allowed STL export when they created it, you could save-as .stl and open that in SWx.
Otherwise, contact the company and ask nicely for the file?
From an .eprt, yes, but not from an .edrw
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
In that case, you're stuck with my "Otherwise" mentioned above.
Can you open STL parts in SW?  If so, do you get anything useful, or just a bunch of triangle surfaces?
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Yes you can.  I've not had any problems with it as of yet.  The only draw back I see in opening this file type is that you are unable to use feature recongnize and also not able to measure the solid part with tools>measure.  You however can use the model to implement into an assembly and etc.
Terry Ables
Micro Plastics Inc.
www.microplastics.com
You can open them, but check the options when you do.  Make sure to bring it in a bodies or surfaces in order to do anything at all.
And yes, it will be a bunch of triangle surfaces . . .
That should have been AS bodies or surfaces
