Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It is good to know that there are groups such as this willing to share knowledge in this money driven economy..."
Geography
caravoy (Mechanical)
29 Mar 05 11:21
I've done a bit of research on the effect of temp on a material's magnetism, but I really need yes or no answer.  Is is pointless to try to pick up an iron piece that is around 1600 deg F with a magnet.  The curie temp is 1420 deg F so iron's ferromagnetism disappears, but paramagnetism remains.  Can I exploit paramagnetism to achieve the same ends?  Thanks.
EdStainless (Materials)
29 Mar 05 12:47
You could defect the path of iron particles, but you will not be able to pick them up.  The para forces are less than the mass.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
MagMike (Materials)
29 Mar 05 14:07
As EdStainless said, a paramagnetic material will not be attracted to a magnet in any measurable sense.
Just wanted to mention: If you had planned to use a permanent magnet to pick up the iron, the magnet would demagnetize when brought near-to or in-contact with the iron at that temperature.  The Curie point of Alnico is 1580 degF.
29 Mar 05 17:37
I presumed that the magnet would be cooled.
These effects are fun to play with.  Some liquid gases have similar properties.
30 Mar 05 10:10
EdStainless, MagMike:
  Thanks for your help.
Close Box
Join Eng-Tips® Today!
Join Us             Close
