SW NOT PROVEN AT ALL - LARGE ASSYS
I would have thought this information would be easy to find, but it has been quite the ordeal. It relates to the handling of large assys in SW. We have a large assembly line with roughly 100 000 parts, about 60 000 non-fasteners and roughly 30 000 unique components. We are seriously considering SW, but have seen no proof that SW can handle assemblies of this size. I understand proper assy practices need to be used and very powerful computers are required, but I have never heard of anything close to even 30 000 components.
SW has shown close to 10 000 part assemblies in demos and claim they can do more, but there is a lot of talk about headaches people are having with large assys in SW on forums such as these. So what I’m asking is this:
1) Can you refer me to any companies that are designing very large assys with SW?
2) Is the SW engine inherently limited in handling large assys by design (i.e. will the program grind to a halt at a certain point, regardless of hardware)?
3) Isn’t managing the simplified versions of parts and sub-assys difficult and doesn’t it introduce additional potential for errors?
We are considering Catia as well, but are worried it is overkill for the machine design we’re doing. I’m very interested in hearing your experiences.
Mark.
RE: SW NOT PROVEN AT ALL - LARGE ASSYS
Managing simplified configurations is only difficult if there is no planning or thought put into creating them (ie., don't suppress features needed for mating). Creating the simplified configs as you go is easier than going back and doing it after the assembly gets too large. Developing good modeling standards will be essential for assemblies of that size.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
If you want a definitive answer go to SolidWorks direct & don't give up till they give you one.
Flores
We've done complicated assemblies on the order of 5K-6K parts. You have to do 4 things to have SW work for you with 100K.
1). Structure your assemblies and sub-assemblies. Bring some order to the chaos. You'll need it when you want to change things. You have to be careful with the mate structure too. Also, don't use multiple part files with the same name.
2). Hardware. Spend the $$$ on ram, cpu, AND video card.
3). Simplify your parts. If you don't need the detail, don't put it in the model. (The catch is you never know when you need the accuracy and higher detail later.)
4). Break out views and detail views on multible sheets of a drawing are very slow. Opening drawings can take a while depending on the detail you put in them.
I am on SW2003SP5.0. My machine is a 3GHz Pentium IV with 2GB RAM and an NVIDIA Quadro4 580XGL video card.
I am managing assemblies with up to 4000 parts. The system runs slowly, probably because it is running out of RAM. My current project has 1414 components, and everything seems to run fine.
If you are considering SolidWorks, I strongly suggest buying your computer from the CAD Vendor. You get the hardware they recommend, and you get hardware support from the guys who know how your CAD works. You did not say what you are upgrading from, but I would be surprised if your current machines could run SolidWorks.
I suspect that part of our stability problems come from badly constructed models. We started off SolidWorks on a large, complex project. Your initial trial and error process should be done on something small that you will not keep referring to, later.
As I read your message carefully, I see you refer to "a large assembly line with roughly 100,000 parts". Is this an assembly with 100K parts, or do you need a library of 100K parts, used to create smaller assemblies?
If it is the library you need, you have just hit on one of the big advantages of 3D CAD.
JHG
We have started to look at Solid Edge because it handles large assemblies much better.
SolidWorks needs to get on top of this and quick!!
He built the assembly using my knowledge of Automation and assembly practices. See FAQ or my website for information on assemblyu practices. He posted this at comp.cad.solidworks and no one believed him. I hope he is watching and will pop in here.
Listening to this story proves that you need to use a lot of foresight, proper mating, good technique, and automation (if required) is the secret to good assembly performance. Hardware plays a vital role in making and working with the assembly so be sure you are using the best... unless you can find that unknown good performance card that he had above... but that was 2-3 years ago.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Chris
ctopher's home site
Jason Capriotti
Smith & Nephew, Inc.
Correction: I was incorrect in saying "SW03" above he was using "SW04". Also he was running XP SP1 and not Win NT.
Dear All,
I am interested in large assembly performance and would like to know if these times are poor, fair, or good.
I'm running SW 2004 sp0
My machine is a Dell 360 w/ 2.4 GHz P4, 3.00 GB RAM, XP PRO SP1, and QUADRO NVS W/AGP8X W/64 MEG RAM
My large assemblyis:
TOTAL COMPONENTS: 15285
PARTS 12439
ASSEMBLIES 2846
It loads in the following times:
Lightweight 56 SEC
Resolving from the LW load 88 SEC
To load fully resolved 3:13 MINUTES
This seems really quick to me but this is my first venture pasted 2200 parts.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Jason Capriotti
You may also want to take a look at Solid Edge V17. Please check the link below;
http://www.solid-edge.com/overview/v17.main.htm
fwc
Solidworks Site:
http://ww
Apparently very large assemblies can be made in SW. Something to consider are simplified configurations with only the minimum features needed in a particular sub-assembly. Also save sub-assemblies as part files when possible.
Flores
Not to sure if you can believe there promotional advertising
http://www
I have gone through the article. Thanks to your statement "Not to sure if you can believe their promotional advertising".
I am afraid ...whatever they claim about Solidworks is just not right! And whatever they claim Pro-E can do is probably right but they had to claim a few false untrue things and "lower" Solidworks in order to prove Pro-E is on the top!! Just one example---
When the article talks about BOM from SW, they say writing down with your hand is faster. In SW it doesnt take more than 3 seconds for SW to come up with a BOM. Well if you have the right templates, less than 3 seconds! How faster else would anybody want the software to work?
When you go in detail there are a lot of things where Pro-E fails and SW gains...but obviously we would not want to get into negative campaigning..
Mechanical Engineer
UG looks really good and might actually be an option. It looks as easy to use as SW and has some good large assy capabilities.
Thanks again everyone, I guess SW isn't cut out for the big stuff, despite what the resellers say.
Chris
ctopher's home site
However, with CATIA, you'll run into it's own unique problems (as will you with any package). The benefit of getting SW, is that you can spend all that extra $$ getting better hardware.
That is, from what I can tell, the biggest help with lg. asmblys. with any program.
WC
Our assys are VERY large and do have mostly simple prismatic components. Curiously, how big are the ones you are building?
Mark.
