opening files
opening files
opening files
Is there anyway to open db files that were created by a later version of ANSYS with newer versions?
I'm getting the following error:
You are attempting to read an ANSYS file that was created on a later release (Release 8.1) than the one currently executing (Realse 20040329.  The file xxx.db was not RESUMEd.
Cheers,
a5kwan
RE: opening files
Hai,
  As an alternative , the file can be converted in to common database file(*.cdb) and can be taken into the newer version.
Logesh.E
RE: opening files
Or just read in the log file for the analysis, file.log which ansys generates. That can be read in any version.
