How can you update the Drawing Template via macro?
We have several revisions of our Title block...
The new versions are saved over the old ones with the same name and location...
To manually update them... you go to the sheet properties and click Reload in the Sheet Format/Size frame...
I recorded a macro... but it (and what I tried to derive from it) did not seem to work...
Any Ideas here?
When dealing with computers, there are 10 things you need to know: one, zero, and the rest is Binary.
-Josh S
RE: How can you update the Drawing Template via macro?
Good advice Cor, I use that exact macro, Lenny is extermely helpful in the world of API.  Also a great source for learning.
Nevermind...
You set the Template to None then Back to the Template...
CODE
Sub main()
  Dim S As Sheet, SP() As Double, ST As String
  With Application.SldWorks
    Set S = .ActiveDoc.GetCurrentSheet
    SP = S.GetProperties
    ST = S.GetTemplateName
    .ActiveDoc.SetupSheet4 S.GetName, SP(0), swDwgTemplateNone, SP(2), SP(3), SP(4), ST, SP(5), SP(6), "Default" ', True
    .ActiveDoc.SetupSheet4 S.GetName, SP(0), swDwgTemplateCustom, SP(2), SP(3), SP(4), ST, SP(5), SP(6), "Default" ', True
  End With
End Sub
-Josh S
Ooops... Looks like you posted before I could finish typing
(There were not any replys when I started...)
Oh well...
Nice link though, I will give you a Star for the link (now bookmared ) and for your effort.
Josh
-Josh S
