BOM's again
BOM's again
BOM's again
Thanks for all the help lately all!
New question: WhenI Insert>Bill of Material. If my asm. has configurations. And i just need to use the default for the BOM, I always get Default/Qty. as the title of the quantity column. Its telling me that the quantities in that calum are associated with that Config. What can be done so it will not show "Default/QTY." and just QTY.?  I cant seem to change this. I've tried to edit the cell but it always comes back.
THANKS!!!
Adam
RE: BOM's again
you need to rename the "Qty." column and exclude the period in the name so that it reads "Qty".
You then can save the BOM as a template and when you insert a new BOM just browse to the template you saved.
I don't know why it works but it does.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP1.1
RE: BOM's again
thanks....forgot about searching. :)
Adam
