Copying Assy's
Copying Assy's
How do I copy an assembly in solidworks if I don't have PDM Works. I have an assy I've been working on at home and I thought i had all the files, and you guys can guess what happen. I know how to do in PDMWorks at work but is there anyway to do it at my home?
Printed Circuit Board Designer
Salt Lake City, Utah
No Substitute for american muscle !
RE: Copying Assy's
Be very organized.
You can drop everything into one directory and methodically copy everything back and forth. You will get the crap you do not want, along with your design, but who really cares. PDM Works will sort it out when you get back to work.
JHG
RE: Copying Assy's
You can use "File --> Find References" to list all components. From there, there is a button to copy all files.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
RE: Copying Assy's
John
RE: Copying Assy's
Thanks for that valuable post. I've been working alot home lately since my skiing accident, if you know what I mean. So my boss moved my computer into my house, so i create parts every day, so I have to leave my new parts in a certain directory structure so that all the engineering department guys can access my stuff. So sometime I have to copies assy's and I have no idea what thirty directories there in I don't have time to find all the new parts I've created or downloaded. So your'e little trick worked perfectly.
RE: Copying Assy's
Flores
RE: Copying Assy's
Thanks, I also do rendering that is a nice niffy trick.
