Hole Wizard -- Could not find face or plane
I am on SolidWorks 2003 SP5.0. I have used the hole wizard to place some holes, and have deleted the surface I attached them to. I am not sure how I did this.
Is there way to re-attach the hole sketch to a surface short of deleting the holes and re-inserting them and re-inserting the parts attached to the holes and the fastener pattern using the holes as a reference?
JHG
JHG
RE: Hole Wizard -- Could not find face or plane
If it is a 3D sketch, edit the sketch and select the point. Delete the coincident relation and add one to a new surface.
The Edit Sketch plane option comes up on regular 2D sketches. It does not come up on hole sketches. That was the first thing I looked for.
Thanks though.
JHG
Try holding the shift key while you drag the hole to another surface
