Panelbuilder 1400E
Panelbuilder 1400E
Panelbuilder 1400E
Whenever I try to open an application In Panelbuilder 1400E
Using windows 2000 professional as an operating system, I
get the error Temp directory path at C:\Documents and Settings\Administrator\Local settings\Temp is too long.
The application fails to open.
                    Thank you for any help Doug
RE: Panelbuilder 1400E
I solved my own problem.  If you are running RSview32 and
PB1400E on the same computer and you require a password to login.  Then, Rsview32 requires a Temp file in C:\Documents & settings\Administrator\Local settings to run. PB1400E will not open applications with a temp file there.  It has to be in C:\Documents & settings. Rsview32 will run with a Temp file in both places, but you have to delete the one in Local settings to run PB1400. You also have to create a Temp file in Local settings to run RSview32.
     Just for anyone's info Thank Doug
AH Rockwell software; a perfect combination with Microsoft! (Heavy note of sarcasm). Just why people continue to write viruses is beyond me, when windows is a perfect virus that can cause all sorts of problems and everyone uses it!
