OP AMP VOLTAGE REGULATION
I AM GETTING A 0 TO -20 VDC SIGNAL FROM AN OSCILLATION SENSOR AND SENDING IT THROUGH AN INTRINSICALLY SAFE BARRIER. THE PROBLEM I HAVE IS I AM USING AN ANALOG I/O CARD THAT DETECTS +/-10VDC. I AM TRYING TO FIGURE OUT IF I CAN USE AN OP AMP TO CONVERT THE RANGE OF MY DC. MY SITUATION REQUIRES VERY LOW ERROR. YOUR HELP/ADVICE IS GREATLY APRECIATED.
RE: OP AMP VOLTAGE REGULATION
You can use an op amp to offset the voltage by 10 volts.  That would gibe you the maximum number of A/D bits if that is what you mean by error.  Of course the accuracy of that 10V offset and the drift of the op amp become a factor.  A simple resistance voltage divider would reduce that -20V to -10V.  That would cut the available A/D bits in half.
IFYOUWANTTOMAKEYOURPOSTINGUNREADABLETHENJUSTOMITSPACESAND
PUNCTUATIONTOOBESIDESTHELOWERCASES.
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
Guys,
Why is this in the SSR's forum? Circuit Engineering would be a far better home for this discussion.
If we learn from our mistakes,
I'm getting a great education!
