Threaded Pipe Installation
Where can I find the minimum and maximum installation torque for NPT threaded pipe? Is there a pipe-fitters manual somewhere? I need this for the design of the threaded body/adapter joint on our threaded-end ball valves.
RE: Threaded Pipe Installation
If I were able to fracture your valve with the amount of torque I could exert through a good pipe wrench's teeth, with a handle of arbitrary length, without stripping the outside surface off the pipe, I'd speak ill of your valve.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
John
