Query In Ansys-Workbench
This is regarding query in ansys work bench.
I was intended to specify radial constraint to cylindrical surface of a part/
I created cylindrical co-ordinate system for the part.Then from Envoirnment->Given displacment->Selected the cylindrical surface->Selected the cylindrical co-ordiante system->X->0.
I solved it. Then written ansys->input file->Imported to ANSYS-> when I reviewed the displacement boundary condition on the cylindrical surface, it was constrained in X-direction with respect to Cartesian co-ordinate system and not radially as expected….
Then I created Cylindrical co-ordinate system in ANSYS. Rotated nodes on the cylindrical surface to be constrained to the active cylindrical system. Specified the radial fixity condition(X=0).Solved it. The results was as expected…..
The query is,
How to specify radial fixity boundary condition with respect to cylindrical co-ordinate system in ANSYS-Workbench…
E.Logesh
The query is,
E.Logesh
RE: Query In Ansys-Workbench
I tried to repeat what you said you did in Workbench. However I was not able to select the cylindrical coordinate system for 'Given displacement'. Are you sure that you were able to select the cylindrical coordinate system while specifying 'Given displacement'?
Gurmeet
I am using ansys version 9.0
First I right clicked on co-ordinate system and created new cylindrical co-ordinate system....
Then from the envoirnment, specified given displacment boundary condition about newly created cylindrical co-ordinate system....
Logesh.E
