software for material thickness calculations
ANYBODY KNOWS WHERE WHERE I CAN GET A SOFTWARE FOR MATERIAL THICKNESS CALCULATIONS?
THANKS,
GEORGE
RE: software for material thickness calculations
Thickness for what?
More information is needed.
Can anyone help with cylindrical vessel weight calculation..
Pressure Vessel Handbook 12th Edition Eugene F. Megyesy
Calculate the plate weight based on thickness, diameter and length, add weight for the heads, contents, internals, piping, supports, paint, insulation, etc.
A pretty vague answer to a pretty vague question.
Good luck.
Brian
See: http://www.cerebromix.com
This software calculates material thickness, weight and shows plate layouts for heads. It calculates pressure vessel body and nozzles by ASME VIII-1.
Good luck,
