polymerized asphalt
polymerized asphalt
Does anyone know what the unit weight for polymerized asphalt is for calculating yields or plan quantities? Illinois DOT assumes 112 lb*in/square yard for all asphalt materials. I know that using the Gmb would produce a better result, but I don't have a specific mix design yet. This would number would just be to get a good estimate that should be within 3% of the actual constructed tonnage.
RE: polymerized asphalt
