Detention Pond design examples
Does anyone know where I can get examples of detention pond designs? I purchased HydroCad Software but seem to have a problem with the results. I review consultants work (not the detention pond part). I am curious because I do not allow consultants to release more Q than is existing once property is developed. Some of the detention ponds I am seeing do not seem right compared to HydroCad results. Again, the detention pond part is not my concern, however, I feel that as a registered engineer to bring it to the attention of the consultant firm submitting the design or to the owners attention.
RE: Detention Pond design examples
You say you are not using the detention part of HydroCAD, but you are comparing pond designs to HydroCAD results... what HydroCAD results are those?
Detention/Retention volumes must be sized using an inflow rate and routed (again, at a rate, not a volume) through outlet devices, given a storage volume. It is a dynamic system; as such, you can't size a storage volume based on a static peak volume in - volume out equation.
I have used HydroCAD and many competitors for over 5 years, and have never found any errors in HydroCAD's computational methods.
HydroCAD does not allow a modification of the Rational Method which I have ever been able to get to agree with other methods. As a result, I don't use Rational with HydroCAD. If I want to design or review Modified Rational calcs, I use a standard, widely-accepted method to create a Modified Rational hydrograph, and manually input the flows into a HydroCAD link, then route that. It is a pain, but it works.
The consultant is correct, in my opinion, to use TR55 for 200 acre watersheds, and statistical models for very large 'sheds. But, be advised: this is a subject of fierce debate in the H&H world, so if you challenge someone's results based on their method, make sure you have lots of evidence to make your case. The consultant most likely chose the hydrograph generation method for a reason.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
Using the Modified Rational approach, the Rational peak is ascended to constantly over a multiple of Tc. It lasts at that peak for a duration, then descends constantly to zero, again, over a multiple of Tc. There are many approaches; some hold the peak for the duration of the rainfall, others hold it for a critical intensity duration, others triangulate at the peak. None are incorrect, but any given one must be substantiated.
The rationale for these are all complex, so, again, if you are challenging someone's hydrographs, be prepared. If you challenged mine, I would bring stacks of references to back up my position. I would also insist on seeing yours.
You can't use 7 cfs by itself to analyze volume. You can't detain a peak flow, you can only detain a volume, and the delta volume is determined by the dynamic Qin:Qout, not by Qp alone.
You need the above hydrograph in, the stage:outlet ratios (governed by the outlet structure) and the volume's stage:storage values.
-Steve
Q=CIA = 12 CFS
12= .9* (I) * .23 (ACRES)
I = 55 IS THAT CORRECT?
The intensity = 55 inches per hour appears wrong.
Suggest you use the HydroCad Model to generate 12 cfs.
Then develop a detention basin that stores 7 CFS.
That was not an actual analysis, it was just an example.
