Cosmosworks for Solidworks 2000
Is there a Cosmosworks version which will work inside Solidworks 2000? If the answer is yes what is the Cosmosworks version?
RE: Cosmosworks for Solidworks 2000
Israelkk,
The easist way to answer that question is to contact a solidworks rep or use the website http://www.solidworks.com.  I am sure there is with that version of solidworks, most likely named the same.
Good luck,
jxc
jxc
I tried to look at theirsites but could not find any info for previous versions of Solidworks just for the current version of Solidworks.
I think COSMOSWorks 6.0 was the version for SW 2000. It's going to be very difficult if you are trying to obtain that version and its license.
hiyer
Thanks, I assumed so too because I have seen reference to Version 7 for Solidworks 2001.
