Human posture analysis, CatiaV5
Is there someone out there that can work properly or has an extensive knowhow with the human modeling modules in Catia V5 ??? Help files do have too many obscur secrets...
Human builder, human posture analysis.
RE: Human posture analysis, CatiaV5
Get your hands on the DSS Training Docs.
Do you need a course or do you need help with something particulary?
Hello Azrael.
What I am trying to do is a static posture analysis of a simple dummy standing with wide stance (about 22 inches between feet). At first I do create a dummy and move the limbs in the desired position. Then I switch workbench to  Human posture analysis. Normally, I should be able to run "postural score" but there are no values in the "postural score" window...
Is there a step by step procedure I could follow ?
Louis
