sp 2.0 upgrade
sp 2.0 upgrade
Has anyone had any trouble upgrading to SW SP2 using an administrative image? I get half way through the install to the point of where I specify path for SW and for common files, I hit "next" and nothing happens. I can go back but no further.
RE: sp 2.0 upgrade
If nothing is happening, someone probably has SW running. Also, do the upgrade at the server, not over the network.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
RE: sp 2.0 upgrade
If so it was at that point in the install that we experiance a long wait time. Seem SolidWorks is checking on something on the server. Give it some time. Also on a side note make sure that your anti virus software is disabled and or unloaded if it is not this can couse the instilation to not continue.
