guardmaster interlock model?
RE: guardmaster interlock model?
I'll tell you the samething I told the other guy.
If you can't find one from the links provided in the FAQ559-520 and no one replies with an answer your going to have to make your own. So check out the links and maybe, just maybe there is one there.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
You will not find a lot of specialty items like this anywhere. In SolidWorks, if you have a data sht or the actual part, you usually can model it faster than waiting for an answer.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
looks like im going to model it then.....just thought there would be an easier way ;o)
callum
Open the file, then start a Save as ... then whatever options you see are the options you have.
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
