Fillet Weld Size Inspection
if Drg. specify Fillet size as 8mm, whether we have to check 8 mm as Throat or Leg ?
RE: Fillet Weld Size Inspection
http://www.arcraftplasma.com/weldingsymbols.htm
http://www.qtm.net/~galgage/product.html
Just looked at a large fabrication with a tremendous number of cracks emanating from bad, bad filet welds. All the welds in question had a very convex throat to the point that there was lack of fusion on one or in some cases both toes of the weld.
http:
Gerald Austin
Iuka, Mississippi
http://www.weldinginspectionsvcs.com
If you think 8mm fillet refers to the throat (troat) dimension then suggest you are in the wrong profession.
Gerald Austin
Iuka, Mississippi
jt
