DIALOG DEFAULTS
DIALOG DEFAULTS
DIALOG DEFAULTS
IS THERE A WAY TO CHANGE THE DEFAULTS ON THE DIALOGS.  FOR EXAMPLE EVERY TIME I PICK GEOMETRY FOR PLANER MILLING I CHANGE THE MATERIAL SIDE FROM LEFT TO RIGHT.
RE: DIALOG DEFAULTS
Do the positions on the entity where you pick have any effect on the bounndry side? Try picking in a counterclockwise direction. The position of the second pick to the first pick used to have a vector effect for establishing cut direction.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: DIALOG DEFAULTS
Change this setting to 1 instead of the default 0 in your ug_cam.def file:
CAM_bnd_typ:       1
Bill
