Rebar attachment to sheet pile wall
I was wondering if anyone is familiar with attaching Reinforing bars to Z shaped sheet piling.
I have a sheet pile retaining wall that is getting a cast in place concrete facing for the portion above grade. I would like for the horizontal rebar nearest to the steel sheeting to be attached.
Any info would be greatly appreciated
RE: Rebar attachment to sheet pile wall
For short pieces that you would probably want, check out deformed bars by Nelson Stud Welding:
http://www.nelsonstud.com/pdf/d2l.pdf
