Export slddrw to DWG, can't get anything but 1:1
What the heck???
I'm trying to export a drawing to DWG.  It contains five views, all set to sheet scale.  Sheet scale is set to 1:8.  When I save as DWG, I uncheck the "Scale 1:1" option, which (I think) should save the DWG at the sheet scale--1/8 of actual size.
I open the DWG in AutoCAD, and it's full size (1:1).  I've tried DWG and DXF, 1:1 checked and unchecked... nothing works.  EVERYTHING I export is in full scale.  Any ideas on what might be going on?  I'll provide more info or files if necessary.  Thanks,
Brian
