Grinding/Drilling Granite
Looking for some idea how to calculate power requirements for grinding and drilling granite. Looking to grind 1/4"-3/8 bevel around rectangular granite block (4" thk) and also drill up to 12" dia hole using standard hole saw. Speed is whatever is considered typical for granite. Thanks.
RE: Grinding/Drilling Granite
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessor.com
look my mr.,i know that drilling brittle materials like granite must be on low speeds relatively.....and it must be done on a machine with very low and damped vibrations..........a 12'' hole.......if the ratio between length and diameter of hole is more than 1:2 so that where the problem starts...and obviuosly there is no problem......the problem will be in fixation and vibrations.
