Problem creating a rectangular array
I have a problem creating a rectangular array. When I make a block (100x100x100 mm), and then make a array of it (2 itemss in X, spacing 300), I get an error 'Tool body completely outside target body'. But this is exactly what I want.
Is there a different way to create such an array?
Regard,
Roy Munnichs.
Regard,
Roy Munnichs.
RE: Problem creating a rectangular array
i think, you really not want make pattern of block:
if you want to make pattern from a region of a body, you can use pattern face under the instance..
but when the instances of the pattern are not connected? i dont know..
kukelyk
strictly speaking, you should try to do what you are doing without creating two primitives.
Kukelyk has you going in the right direction with Edit>Transform>Rectangular Array, providing the blocks don't require associativity.
If your looking for associativity between the solids (as in one body drives the distance between/size/shape of the others), I think EWH was on target with grouping the body and arraying the group. This allows you to have an array of seperate solids in the file, all associated to the initial solid. To accomplish this;
- Application Modeling/model nav, highlight body so that the body is higlighted in the list
- Right click (3rd button, whatever), click 'group', follow the bouncing ball. I'd recommend hiding the features, but to each his own (keeps the model tree cleaner and if a downstream user tries to edit, the 'group' feature comes up which should clue them in...
I think this approach is worth looking into.
Shadowspawn
The early bird gets the worm,
But the 2nd mouse gets the cheese!
While I'm on it, whoever added Mirror Body without adding Array Body to UG should be shot. A sore spot? Just a little....try modeling a freeformed wheel sometime & you'll see my frustration. Group Feature to the rescue, however I still think UGS must improve its arraying capabilities (limitations in my eyes).
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Tried the Patch & Trim Body arrays (just to make sure it wasn't too good to be true) - both worked as you said. Once again, your insight and this forum have been very useful. Thanks!
-Rod
Just be careful using it. I wouldn't pile a bunch of features into one grouping. As Azrael said, there can be problems from time to time.
Also, there is a hard-coded factory icon that isn't usually available for Group Feature (at least not in any version up to NX2). If you would like to have the Group Feature icon available, just edit the Feature Operation .tbr file & add the following:
BUTTON UG_MODELING_GROUP_FEATURE
LABEL Group Features...
BITMAP Group
I placed this after the Instance Feature icon. If you're running NX3, this icon will not resemble the newer XP icons.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
