How to measure perpendical distance between point and face in NX3
Does anybody know how to measure the perpendicular distance between a point and a face? When I use the option "Minimum distance", it does not use the perpendicular distance.
Any help is appreciated.
Roy Munnichs.
Roy Munnichs.
RE: How to measure perpendical distance between point and face in NX3
if you select projected distance, you can define a vector...
kukelyk
