keyword comparison
keyword comparison
does anyone know how the keyword "out" in quickbasic is now implemented in vb6 ?
RE: keyword comparison
Evan T. Basalik, MCSD
It's all about prioritization...
Remember...
"If you don't use your head,
your going to have to use your feet."
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
out &h200,&h2 would make bit 2 of port 200 go high or turn on. inputs would be inp(&h200). I just assumed there has to be a way to still write applications for these boards. They
are actually quite versatile. 16 inputs and 16 outputs. Quite a bit of control to the outside world with this.
Any thoughts now with a little more detail?
thanks
There are also example programs etc.
Hope this helps.
Good luck with your projects.
Robin
http://www.lvr.com/index.html
Good Luck
johnwm
