Inclined grade beam and pier foundation
When designing the foundation system for residential customer built house at the hill side with steep slop, say 25 degree, can the concrete grade beam be designed parallel to the slop in general (inclined the grade beam instead of stepping the grade beam)and connect the grade beam to the pier foundation as usual? Any idea, experience, or suggestion? I am thinking of using step grade beam. However, the slop is too deep and regrade is kind of difficulty.
RE: Inclined grade beam and pier foundation
The optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer see the glass as too big.
Since you did not mention the framing material, I presume you are using masonry (wood framing wouldn't be an issue). Make your steps in increments to match your CMUs or bricks (usu modulo 8").
Hope that helps! RAF
James
