Best software combination for composite/metal assembly
What would be best software combination for FEA of an assembly consisting of carbon/epoxy/honeycomb core monocoque with alu bulkheads and potted hardpoints. Tubular subframes and various brackets bolted to composite structure. Monocoque may have non uniform lay-up i.e. additional ply's or C/F tape in critical areas, lap joints etc.
Main criteria’s:
Capability to import relatively complex assembly from CAD (SolidWorks)
Exceptional capabilities to model composites – draping etc.
Easy to use/user friendly, intuitive interface a
It doesn’t matter if it will be a combination of more than/two packages.
You opinion/advise is highly appreciated.
Thank you
Adrian
PS: For now I started learning/trying MCS.Patran as preprocessor but I've heard that it's not the only or best solution.
Main criteria’s:
Thank you
Adrian
RE: Best software combination for composite/metal assembly
