Best software combination for composite/metal assembly
 What would be best software combination for FEA of an assembly consisting of carbon/epoxy/honeycomb core monocoque with alu bulkheads and potted hardpoints. Tubular subframes and various brackets bolted to composite structure. Monocoque may have non uniform lay-up i.e. additional ply's or C/F tape in critical areas, lap joints etc.
Main criteria’s:
 Capability to import relatively complex assembly from CAD (SolidWorks)
 Exceptional capabilities to model composites – draping etc.
 Easy to use/user friendly, intuitive interface a
It doesn’t matter if it will be a combination of more than/two packages.
You opinion/advise is highly appreciated.
Thank you
Adrian
