Pressure Drop Questions
OK I have a few questions about a problem in our glycol chilling units.
A brief description:
Glycol is pumped and fed to two different precooling units (exchanger and compressor) in a continuous loop. The one side passes through 2 expansion tanks and the other just one (1 common exp tank for each). We are getting back flow into one expansion tank and its overflowing (both are pretty much atm pressure).
Would pressure drop through the pipe cause this to occur (suction pressure of the pump is 400 psi so if pressure in pipe goes less than 400psi backflow can occur). Discharge is 1000 psi
In general is that the main thing pressure drop gives you in all applications. How does pressure drop come into play with design and troubleshooting?
RE: Pressure Drop Questions
Good luck,
Latexman
